Tech II not able to connect???? WTF?
Allright, I have tried multiple Tech II's to ensure it's not an equipment issue, I just cant seem to get them to connect to the truck's computer!!! My EFI live V2 connects up and functions perfectly, loggs, DTC's and the like. Any idea's on what I should look to so I can get the Tech II to work? I need to run the ABS bleeding sequence and get rid of this horrid sponge pedal
Well, since the V2 is operating and my cell charger works, I'm going to assume the 12V pin is hot. Is that a correct assumption?
Specifically when I tried to pull codes or perform an operation, it would try to do what I asked it, then say cannot connect to vehicle or something of that nature.
hmmm....
The cig lighter outlet is fused seperately from the accessory outlets that are right next to each other. The cig lighter fuse also powers the ALDL connector. So, basically, I dunno. I learned long ago never to assume.
I know, I know, assuming ..........
