Tail Light doesn't come on until braking..
Old Jan 28, 2012 | 11:56 PM
1FastBrick's Avatar
Custm2500's Rude Friend
check for continuity in each wire on the tail light harnes. If it's all good then its not the lights harness. you will have to move on to the rest of the wireing. I have the book but dont have a diagram that I can up load right now.
Old Jan 29, 2012 | 12:01 AM
oakley6575's Avatar
Okay but it has to be the wiring after the rear connector box correct? If every other bulb in the tail lights work correctly, it can't be something before the box right?
Old Jan 29, 2012 | 12:03 AM
1FastBrick's Avatar
I will have to look at the diaghram. I am not sure if its 1 signal and split at the box.
Old Jan 29, 2012 | 12:05 AM
oakley6575's Avatar
Okay, thanks for your guys' help.
Old Jan 29, 2012 | 01:15 AM
black04's Avatar
They are seperate. Not split.
Old Jan 29, 2012 | 01:22 AM
oakley6575's Avatar
Since they are separate, I can run a jumper wire then right?
Old Feb 3, 2012 | 03:11 PM
oakley6575's Avatar
Okay, I need to fix this ASAP. Anyone have a wiring diagram that could show me what two wires to jump together? It's not the correct way to fix it but I have to get my truck inspected for registration right away? Any help?
Old Feb 3, 2012 | 08:45 PM
oakley6575's Avatar
Bumped
Old Feb 4, 2012 | 03:02 AM
letsrun97z's Avatar
Could it possibly be the switch?
Old Feb 4, 2012 | 12:00 PM
oakley6575's Avatar
Every other rear light works except the passenger running light. That bulb lights up when you hit the brakes but the night time running light is out. So I don't think it could be the block but you never know. I just can't find any wiring diagram to see which wire is the running light and which is the brake wire..
