Tail Light doesn't come on until braking..
Old Jan 28, 2012 | 10:00 PM
oakley6575's Avatar
Default Tail Light doesn't come on until braking..
The passenger side tail light is completely dark until I hit the brakes. Then the bulb will light up.. How would I fix this?
Old Jan 28, 2012 | 11:06 PM
black04's Avatar
New bulb. One of the filaments is burned out.
Old Jan 28, 2012 | 11:08 PM
oakley6575's Avatar
I have put three bulbs in it and still does the same thing.
Old Jan 28, 2012 | 11:09 PM
black04's Avatar
hmm check your fuse?
Old Jan 28, 2012 | 11:11 PM
oakley6575's Avatar
Yes all the fuses are good. The only thing it could be is the actual wire right?
Old Jan 28, 2012 | 11:12 PM
black04's Avatar
You could test it with a voltmeter see if its getting power.
Old Jan 28, 2012 | 11:28 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Its the wireing. I had a freind with a similar issue. check your connections at the light first. I have seen the sockets have issues and the junction under the bed have poor connection issues.
Old Jan 28, 2012 | 11:35 PM
oakley6575's Avatar
I don't know what wire it is. There are three wires going to that particular bulb. Any idea?
Should I just run a jumper wire from the drivers side bulb?
Old Jan 28, 2012 | 11:37 PM
1FastBrick's Avatar
turn the light system on. go back and wigle the wires see if one lights it up.
Old Jan 28, 2012 | 11:50 PM
oakley6575's Avatar
Yea they the bulb still doesn't come on. I also disconnected the plug from under the truck and everything seemed fine.
Any more ideas?
