strange ignition issue
Old Aug 22, 2009 | 04:43 PM
Midnightrider's Avatar
Default strange ignition issue
Quick background. last week fired the truck up it ran on a sd tune in open loop no 02 sensors i fowled out the plugs. This week i replaced the plugs got ythe exhaust finishe and the 02s in and she started and ran but now she wont restart. It atempts to start some times ive gone threw 4 sets of plugs just to be sure this set is good. gaped between 33-35. Everytime i replace the plugs it starts but wont restart after it runs. I found a vacuum leak and fixed it. the FP is good 45psi which is what my injectors are rated at . Here is the strange part if i shoot ether in it it starts fine and runs fine. it is throwing a po102 which is a maf code but im on a 3 bar sd tune. Can some one please tell me wtf
Old Aug 22, 2009 | 04:50 PM
00ChevyScott's Avatar
Wearin' da big hat
Have you checked with noid lights to make sure your injectors are firing?
Well just read that you said it will start and run with a bit of ether right? How long does it stay running, and is it driveable?
Old Aug 22, 2009 | 04:55 PM
i give it one squirt on each breather and it fires and stays running and is drivable
Old Aug 22, 2009 | 04:56 PM
its driving me insane it doent make any sense
Old Sep 15, 2009 | 11:55 AM
KySilverado's Avatar
You should have a MAF code when in SD. Failed so that it won't look at the MAF. It sounds like tune to me. Cold/First start enrichment routines not right. Possibly idle air.
Idryfly5
Sep 2, 2022 08:55 PM
GMCtrk
Sep 11, 2015 09:04 AM
cousblake11
Sep 9, 2015 06:52 PM
SWINGRRRR
Sep 3, 2015 07:49 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
