Strange A/F Wierdness
Old Jun 2, 2007 | 12:58 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Default Strange A/F Wierdness
Something that has bothered me for a while, my a/f is fine WOT and PT but just cruising around but sometimes (after the engine/trans is fully warmed) the a/f pegs out lean 17/1 at steady throttle in tc lock. If I blip the throttle it will return to normal but soon go way lean again. After a while it'll run 13's rich and then stoich again. All this at steady cruising throttle.
I replaced the wideband O2 with same results. This started happening immediately after going to the true duals.
Thoughts? I dont have any scanning software (someday) and it never does it on a short ride with my tuner scanning, lol. He says it's not a concern, that it's just the 'trims' but it does feel differesnt (and it sounds different?) when it goes lean like that.
Old Jun 2, 2007 | 07:31 PM
KySilverado's Avatar
Thinking....... ummmm yeah that is strange. My first thought was o2's but apparently so was yours. It does sound like trims but its trimming for a fueling problem and to slow it sounds. Has to be tune related and I personally would be concerned cruising at 17/1 AFR for any extended amount of time.
Old Jun 2, 2007 | 08:01 PM
Blown06's Avatar
8 Second Truck Club
Mine does the exact same thing. Haven't addressed the issue with Allen Nelson yet but will on Friday.
Old Jun 2, 2007 | 08:02 PM
trever1t's Avatar
I am concerned but my tuner says it's not an issue. As soon as I apply any throttle it goes where it should. Could a very small exaust leak in front of the O2 cause it to do that but not be heard?
Really, keep me posted if you find a cause!
Old Jun 2, 2007 | 08:18 PM
trever1t's Avatar
I only replaced the WB o2 which of course is only reading - not affecting. If a forward o2 was weak or burnt would it throw any codes?
Old Jun 2, 2007 | 08:38 PM
Yes a small exhaust leak could cause this IMO and yes a weak/slow o2 could also, especially if it doesn't stay heated to similar temps via the exhaust flow, and not throw codes again IMO.
Old Jun 5, 2007 | 10:26 PM
Stoichiometric's Avatar
Just found this thread, mine does the same! What bothers me is when I am climbimg a hill I'll see 17:1 under a pretty good load. I have to get into PE/boost to make it change. My gauge sweeps back and forth between 14 and 17. Strange!
Old Jun 5, 2007 | 10:31 PM
trever1t's Avatar
I talked to Rick some more about it today and agian he really doesnt think its anything to be concerned with but we'll take a ride soon and see if I can captute it while he's plugged in.
Henry, mine comes back down as soon as I give it any peddle. You have tuning software, have you scanned the event?
Old Jun 5, 2007 | 10:34 PM
BlackGMC's Avatar
Resident Retard
Maybe your O2's are a little dirty, you might try cleaning them? I mean you are throwing a ton of gas, meth and nitrious into the motor. I may be way off, but worth a shot
Old Jun 5, 2007 | 10:36 PM
No, I have only experienced it cruising on the hwy. I am also not smart enough yet to get scans that show me more than the digital dashboard in EFI live . I'll look around for a tutorial or something, I need to put my software to better use!
