Strange A/F Wierdness
Old Jun 5, 2007 | 10:40 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Originally Posted by BlackGMC
Maybe your O2's are a little dirty, you might try cleaning them? I mean you are throwing a ton of gas, meth and nitrious into the motor. I may be way off, but worth a shot
Dirty or burned out How the hell do you clean an o2 sensor?
Originally Posted by Stoichiometric
No, I have only experienced it cruising on the hwy. I am also not smart enough yet to get scans that show me more than the digital dashboard in EFI live . I'll look around for a tutorial or something, I need to put my software to better use!
Keep it plugged in next time you plan on some highway time. I'm sure a couple of the tuning guru's around would be interested in seeing it
Old Jun 5, 2007 | 10:44 PM
BlackGMC's Avatar
Resident Retard
Unscrew them and spray them off with O2 safe carb cleaner.
Another thought, you guys that are experiencing this, do all of yall have CATs still on? I noticed 2 of you were from CA, so I am guessing you have CATs. Keeping the similarities in mind your cats might be clogged, and at low throttle not as much volume or flow is created by the engine causing a bottle neck in front of the CAT, then when you goose it more volume and it blows harder threw the CAT. Once again I may be way off, but just a thought.
Old Jun 5, 2007 | 10:46 PM
BlackGMC's Avatar
Resident Retard
Never mind i just noticed that 1 person experiencing the same problem has a ORy.
Old Jun 5, 2007 | 10:50 PM
trever1t's Avatar
plus my cats are relatively new and hiflows. It started for me right after the swap to true duals. I'm thinking a sensor is damaged or a very small leak?
Old Jun 6, 2007 | 12:11 AM
Blown06's Avatar
8 Second Truck Club
I drove the truck alot over the weekend and it seems to have stopped doing this. It happened on the first drive with the entirely new combo and nelson mail order tune. Happened like 5 times that night however, haven't seen it since. Like I said earlier though, I'll ask allen on friday.
Old Jun 6, 2007 | 05:36 PM
Stoichiometric's Avatar
Bill, is your VE tuned? I am running on a stock VE and MAF table. I think that may have something to do with it.
Old Jun 6, 2007 | 06:53 PM
trever1t's Avatar
No clue.Rick does the tuning. We're going to be doing some more on the street soon so we'll be checking it out.
Old Jun 6, 2007 | 08:06 PM
03sierraslt's Avatar
Mine used to do the same thing when I was running the MAF, then I realized one day while VE tuning that the issue went away. Low and behold since I switched to OLSD its gone. Trever1t mine used to do the exact same thing, sometimes lean sometimes rich but as soon as I put any load on it it went to 14.7 I did numerous things to trouble shoot the issue and everything was fine... It went away anytime the MAF was taken out of the equation. Mind you my MAF table was tuned to within -2 to 0 Error so it wasnt that the table was off.
Old Jun 6, 2007 | 08:09 PM
When I was logging and this occured my 02's would corespond to my wideband readings and you could see the fuel trims go + or - to correct it. I still have no idea what was causing it, tried different 02's, different MAF nothing made a difference..
Texas5.3_1251
Mar 5, 2016 08:10 PM
dantheman1540
Feb 24, 2016 09:56 PM
91LT16SpeedFormula
Oct 17, 2015 08:01 PM
Boyes50
Sep 8, 2015 12:06 PM
