Stats on tuning session yesterday
Old Mar 2, 2006 | 10:03 PM
Last Call's Avatar
TOTM: January 2007
Default Stats on tuning session yesterday
Had my truck tuned yesterday. Mods are in sig.
I am running 7.5lbs (3.25 pulley) of boost with the radix. (other mods in the sig)
I am running a total of 17 degrees of timing.
Intake temps before a run were around 110, and after about 160.
Injector duty cycle is at 89%
Pulling in 56lbs of air
Do any other radix guys have any of there tuning stats? Just want to see how they compare.
Old Mar 2, 2006 | 11:41 PM
04Denali's Avatar
If you want I can scan any info you want with mine and let you know. AIT's seem kinda high, When it was 105* outside mine never got higher than 135* I am spraying meth though. I have a huge new heat exchange I will be putting on in a couple of weeks and hop to drop them by another 20*
How do you check for your injector duty cycle? My logging software is AutoEnginuity if that helps
Mark
Old Mar 3, 2006 | 11:26 AM
Last Call's Avatar
TOTM: January 2007
The tuner logged it with HP tuners logging software/
Old Mar 4, 2006 | 11:18 AM
Mort's Avatar
Cool
Originally Posted by 2004Denali
<snip>....How do you check for your injector duty cycle? My logging software is AutoEnginuity if that helps
Mark
I don't think that you can log that using GM Enhanced Parameters in AutoEnginuity. At least I have not yet found a way to do it. I have not yet done a exhaustive search but did not find it under powertrain. If you do find a way please let us know.
Old Mar 4, 2006 | 11:52 AM
foff667's Avatar
LS1TECH Sponsor
injector duty cycle is a calculation rather then a pid...hpt does the calculation for you.
Old Mar 4, 2006 | 05:54 PM
Use this. It is an Excel file when unzipped.
File Type: zip
Old Mar 5, 2006 | 06:55 PM
KySilverado's Avatar
Not on a dyno. I posted a WOT log from the track
https://www.performancetrucks.net/fo...d.php?t=358385
9psi
20 degrees timing
IAT at 117 after the run
58 lb of air
90% duty cycle
Old Mar 5, 2006 | 08:33 PM
Holty's Avatar
Notorious BIG
9psi
20 degrees timing
58 lb of air
90% duty cycle
are you logging/scanning with hptuners? if so, how do you log IAT's and lb of air? thanks.
Old Mar 5, 2006 | 08:57 PM
Yes, right click the chart, chart settings, and choose what units and pids you want to log.
ZONES89RS
21
Sep 24, 2015 05:58 PM
TX Tahoe Z71
Sep 1, 2015 09:11 PM
LETHL_SS
Aug 16, 2015 06:58 PM
Atomic
Jul 22, 2015 03:41 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
