What a dyno screen shot should NOT look like
Old Mar 5, 2006 | 12:58 PM
kbracing96's Avatar
Default What a dyno screen shot should NOT look like
This is a "certain" members truck (not mine) with a STS and stock fuel system trying to run 10 lbs of boost. Notice the injector duty cycle and the actual A/F (top) verses the commanded A/F (bottom). Luckily he was still able to drive home (100 miles) even after making a second run that was even uglier
Old Mar 5, 2006 | 02:31 PM
foff667's Avatar
LS1TECH Sponsor
yeah he MIGHT just wanna consider some slightly larger injectors...182% seems like he just might be running out lol
Old Mar 5, 2006 | 04:44 PM
DrX's Avatar
DrX
Calculated inj duty cycles would be somewhat lower if commanded AFR was something like 11.0 :1 but would still be way over 100%. Looks like he was out of injector before 4000 RPM at a commanded AFR around 10.0:1. Could probably set the rev limiter to 4500 RPM with a commanded AFR of say 11.0:1 with no safety factor. But what fun would that be!
Old Mar 5, 2006 | 09:03 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Ouch. Thats a big KR spike.
I think your friend should not leave the house -- he's used up all his luck for this year
Old Mar 5, 2006 | 11:37 PM
kbracing96's Avatar
You should see the KR on his second run Can you say 8*...?
All most needed a bucket to take the pieces home
The dyno guy did tell him they had a mop and a bucket he could use to clean up the mess if he wanted to go again
Old Mar 6, 2006 | 09:11 AM
white1's Avatar
And I was worried with my 132% hmph, maybe Ill put the smaller injectors back in
Old Mar 6, 2006 | 09:25 AM
TG02Z71's Avatar
I think I just soiled myself!!
$A_Money$81
Mar 27, 2023 10:25 AM
twake_410
Apr 14, 2016 09:58 PM
Lthompson
Oct 2, 2015 12:45 AM
jscherbs
Sep 30, 2015 07:54 AM
Slammed silverado
Sep 28, 2015 06:14 PM
