Speedometer stuck at 70! Help
Old Aug 30, 2007 | 07:01 PM
Hugger's Avatar
10 Second Club
Default Speedometer stuck at 70! Help
This is on an 04 EC Silverado Z71. The speedometer is stuck at 65-70 mph. It will not go down to 0 even when the truck is turned off. This happened with the cruise on and now it will not go back down. I have used efilive to confirm that the vehicle speed sensor is reading the correct speed but the needle will still not move. The problem seems to be in the cluster. Anyone else had this problem or have any ideas on how to fix it?
Josh
Old Aug 30, 2007 | 07:04 PM
dirt track racer 81's Avatar
even if you get over 70 it stays there?
Old Aug 30, 2007 | 07:17 PM
RoosterMcCandles's Avatar
I thought I remember somebody having a similar problem (but it wasn't stuck at 70) and it was like a pin or something stuck in the cluster...
Old Aug 31, 2007 | 10:25 AM
Coban's Avatar
It could be your stepper motor in the cluster for the speedo. the one for my oil pressure went out and it behaved like that. The one in my dads tach also went out, but it would just read half the actual. They were both 04's. Its kinda a common problem.
Old Sep 1, 2007 | 01:13 PM
chevymec's Avatar
The cluster needs to be replaced or sent off to be repaired. It happens all too often. You might try to take the cluster out and unplug it. Sometimes it will work for a little while.
Old Sep 1, 2007 | 04:42 PM
gmforlife's Avatar
ditto
Old Sep 1, 2007 | 05:40 PM
KySilverado's Avatar
Prolly the stepper motor.
Have a look here.
https://www.performancetrucks.net/fo...hlight=stepper
trxmxzx
Sep 24, 2015 09:29 PM
Shotguntommy
Sep 15, 2015 05:24 AM
mayko
Sep 7, 2015 12:24 PM
MileHighSierra
Jul 22, 2015 11:19 PM
