Solve the mystery?
Old Sep 12, 2012 | 08:31 PM
GMJim's Avatar
Dealer replaced all power cables from the battery. Waiting to see the results. I'll let ya know!
Jim
Old Sep 13, 2012 | 08:27 PM
bigredexpress99's Avatar
Vehicle has had 0 incidents since replacing positive battery cable from battery to started and junction block. apparently that hadn't ever been replaced.
Old Sep 15, 2012 | 12:08 AM
The Plug on the main 12V cable to the UBEC is a quick connect plug I bet the blade began losing tension. These damm new cars have so many things that can cause identical symptoms will drive a tech or customer to drinking trying to nail down glitchy dang little problems.
Old Sep 22, 2012 | 10:29 AM
GMJim's Avatar
So far so good. You would think the newer computerized everything cars would have a solid electrical supply??? I guess GM thought they could save a nickle or two with their cheap connectors. Anyway day 9 and no abnormal electrical problems. I'll be back later with an update.
Old Sep 22, 2012 | 01:05 PM
02 BLK WS6's Avatar
10 Second Club
I'm kind of late.
The factory battery cable ends that GM used are complete garbage. After a couple electrical problems with my truck. I replaced the battery cable ends on my truck with brass and have had zero issues since. I could have had mine replaced under warranty but didn't want the same factory junk.
Old Oct 25, 2012 | 08:21 PM
GMJim's Avatar
Well it would seem a bad connection was the problem. Time will tell.
69z-28
Sep 21, 2015 07:31 AM
Sp8s81
11
Aug 26, 2015 03:54 PM
05GMC4.8
Aug 7, 2015 09:55 PM
hartinclay
Aug 3, 2015 07:03 PM
121
Jul 16, 2015 12:18 AM
