Smoothing VE tables ??
Old Jun 21, 2006 | 05:26 PM
thunder550's Avatar
High on diesel fumes
Looks like one of those spikey things you would fall into playing Mario Bros.
Old Jun 21, 2006 | 05:51 PM
Magnus's Avatar
LS1TECH Sponsor
Upgrade to VCM Suite 2.x already! Its free!!!!
Old Jun 21, 2006 | 06:17 PM
Yelo's Avatar
What the hell happened to that VE table ??.....it looks like Bart Simpsons hair !!!
Old Jun 21, 2006 | 06:28 PM
dewmanshu's Avatar
Moderately Differentiated
LOL I believe he did, waiting on the full license/full edit cable I bethca.
I just started the .00001 thing yesterday, definitely helps keeping values close to there starting point, hence resolution.
Old Jun 21, 2006 | 06:49 PM
kbracing96's Avatar
Here is my latest VE table. Started hand smoothing a few weeks ago, 6-20 cells at a time so it all look smoother, and the truck feel much smoother when driving and BEN's are still +/- .01 to right on. Now, the boost VE table not as pretty, need to work on it a little. One thing at a time
Old Jun 21, 2006 | 07:23 PM
dewmanshu's Avatar
HOLY SHITZKIE kb, if you are getting +-.01's out of that table, you've certainly impressed me! That is exacty how I'd picture any good FI table to look. That graph only goes to 105? (not familiar with EFILIVE) ?Do you have a different table(graph) for Boost?
How about MPG, being that smooth and CORRECT, did you notice any better MPG's?
Old Jun 21, 2006 | 08:50 PM
kbracing96's Avatar
Boost VE table isn't so pretty, but the tune is pretty close for the kPa I'm running, just haven't had time to clean it up and gas cost to much to tune it right now,
****EDIT****
Actually, I lied, this is my current Boost VE table. (I though I had smoothed it ) Had the wrong tune loaded when I pulled the print screen
Old Jun 21, 2006 | 08:59 PM
kbracing96's Avatar
MPG's are a little better, around 16-18 now highway (14-15 before tuning). The Z06 cam KILLED my MPG with this little motor, just doesn't make enough power preboost low RPM. But remember, I'm at about 4800ft and there isn't any flat land to be see around here, I have to make 2+ psi of boost just to get to 100 kPa. And I just switched to a MP T-70 turbo that dosn't spool as well at low RPM highway speed.
Old Jun 21, 2006 | 09:14 PM
dewmanshu's Avatar
Ahhh, so you are PE and Boost VE'ing constantly. Nevertheless, looks good for clean fuel trims!
Old Jun 21, 2006 | 09:32 PM
kbracing96's Avatar
Actually, I don't use PE or LTFT. I use this.
It's EFILives Custom OS 3 Commanded fuel vs. rpm table. Anywhere that 14.68 is commanded, it uses STFT to correct the fueling. Everything else runs open loop strictly off the VE tables. (Notice the lean cruise in there )
