Setting up CLSD
Old Apr 22, 2008 | 11:00 AM
thunder550's Avatar
High on diesel fumes
This is the table I use for all my fueling. Do you guys running the stock OS have this table?
Old Apr 22, 2008 | 11:07 AM
Stoichiometric's Avatar
In cos3 the PE becomes redundant. You can still use it for extra enrichment if you want to set the enable kPa to 150 for example and command a richer ratio than what is in the commanded AFR table.
I think charcold-bowtie's PE still becomes active in his tune. He is on the right track adjusting the VE at 3500+ until his fuel matches the 12.2 he is commanding.
Old Apr 22, 2008 | 11:09 AM
B3605 is in his tune, it is similar to 3647 except it only has MAP and ECT.
Old Apr 22, 2008 | 11:15 AM
thunder550's Avatar
Interesting...I did not know that. I was planning on bumping my boost up past the limits of the 2 bar MAP that I have, and it sounds like PE might be a good way to get the extra fuel. Thanks
Old Apr 22, 2008 | 12:41 PM
dc_justin's Avatar
Hello Dave
Old Apr 22, 2008 | 12:57 PM
Originally Posted by dc_justin
I learned from the best ^^.
Old Apr 22, 2008 | 02:49 PM
charcold-bowtie's Avatar
Thanks for all the info guys, it will be benificial when i finally get time to swithc the OS. I do think my problems are in my VE i was having problems with the wideband connection so i dont even remeber how accurate this one is anyway. I will try to grab a log this evening is possible. My problems now are in OL, other than that it runs fine. I mean cause even if PE is stepping in, why would my afr go to 10-1 or less,,, off my gauge.
Old Apr 22, 2008 | 08:44 PM
heres a log from a while ago. It is realy ugly. Wideband pids are in there as well. ltft show to be maxed out, yet they wernt the other day. I wonder if i mixed up a tune. But here it is. thanks
File Type: efi
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
iregret
Sep 10, 2015 09:00 PM
BigEd_72455
Aug 8, 2015 07:37 PM
Sexyrado327
Aug 2, 2015 04:08 PM
lo4x4
Jul 5, 2015 05:58 AM
