Setting up CLSD
In cos3 the PE becomes redundant. You can still use it for extra enrichment if you want to set the enable kPa to 150 for example and command a richer ratio than what is in the commanded AFR table.
I think charcold-bowtie's PE still becomes active in his tune. He is on the right track adjusting the VE at 3500+ until his fuel matches the 12.2 he is commanding.
Thanks for all the info guys, it will be benificial when i finally get time to swithc the OS. I do think my problems are in my VE i was having problems with the wideband connection so i dont even remeber how accurate this one is anyway. I will try to grab a log this evening is possible. My problems now are in OL, other than that it runs fine. I mean cause even if PE is stepping in, why would my afr go to 10-1 or less,,, off my gauge.
heres a log from a while ago. It is realy ugly. Wideband pids are in there as well. ltft show to be maxed out, yet they wernt the other day. I wonder if i mixed up a tune. But here it is. thanks
iregret
Sep 10, 2015 09:00 PM
