SES light coming on and off
Old Nov 15, 2006 | 09:30 PM
gtosilverado's Avatar
Default SES light coming on and off
my SES light keeps blinking then stays lit, after a while it goes away, i took it to autozone and the scan thing said it was misfiring... my truck only has 62k. wut might be the problem ? maybe bad pcm ?? i just switched my stock for a w4m .? could that be the problem ?
Old Nov 15, 2006 | 10:00 PM
dewmanshu's Avatar
Moderately Differentiated
yep..misfiring. Call jesse, tell him you have misfiring in your tune. See if he can straighten you out.
Old Nov 15, 2006 | 10:05 PM
will do. thanks.
Old Nov 15, 2006 | 10:15 PM
jakebdb56's Avatar
hey gtosilverad, this is kinda off the topic but where you at HRP this past friday? jw, I saw a truck just like yours out there. Im goin out there this friday too to get some new times, PE wasn't enabled in my last tune so i never entered it until just before I trapped.
ne ways,
good luck with the tune, and fix that misfire fast w/e is causing it.
jake
Old Nov 15, 2006 | 10:33 PM
no, i wasnt at the track, but i am goin this friday (17th) maybe ill see you up there. Im going to test out the tune on friday and see what kind of times i get. if im not happy im just going to ask for a refund. But if its ok, ill just send it back to get that misfire fixed and change other stuff i want.
Old Nov 15, 2006 | 10:39 PM
blake2kz71's Avatar
may have to do the crank relearn, is that the only code it was throwing was the misfiring? when i did the 02 pcm upgrade i had to do this, it was showing misfires and w/e the crank relearn code is.
Old Nov 15, 2006 | 10:42 PM
yeah, i think it has both, the guy at auto zone only said the misfires but... i saw the lil scanner and it saw 1 of 2. but he didnt tell me the second one.
Old Nov 15, 2006 | 10:48 PM
blake2kz71's Avatar
yulp....go ahead and get the crank relearn done, it cleared both of mine (misfires and crank relearn) when i got it done. Whatever you do try to find somebody that has a good scanner and dont take it to the dealership. It takes all of 2 minutes to do and the dealership charges a full hour of labor. around here its $70 per hour----i pretty much told the manager he was crazy and walked out and took it to my mechanic.
Old Nov 15, 2006 | 11:03 PM
im going to take it to my old high school to the auto tech teacher...... they have snap on scanners and top notch stuff, im pretty sure he can do it, he knows alot about the new technologies
Old Nov 15, 2006 | 11:08 PM
blake2kz71's Avatar
yeh it should, no **** it may not even take 2 min maybe 1 all you do is hit start on the scanner and rev to 4k rpm and it will sound like it hits the rev limiter or something and thats it. oh and btw i had to explain to the dealership what i needed done and why, that turned into a big "hell no your touchin my truck".
