service brake system
just put some 305/50s in the back, and look badass imo, they are taller than my fronts. now my service break sytem is popping up, im thinking it has to be the speed sensors or something because of the different size tires spinning, can this be fixed in the tune, (wheatley) or can i go to a local dealership?
if you haven't tuned it yet for the tires then that is the problem. The computer thinks your fronts and rears are running at different speeds since it doesn't know you changed the tire size.
not sure if the dealer will be able to change the gear size on a tuned pcm. I guess it depends on if the tune is locked or not?
SLOPONY
20
Oct 18, 2016 06:05 AM
Corvette454l88
Sep 1, 2016 01:24 AM
97aztecgt
Aug 13, 2015 02:11 PM
, i fixed the title for you
