Sd not seeing commanded PE?
Sheet...I gotta stay out of these threads. I do the sorriest thing of all...assume 2bar when someone has boost even though he did say MAF, therefore 1bar 99.9% of the time. SIGH. My bad. I am crawling under my rock now.
If you have settings to enable pe and you are 1bar it will still try to meet your target but it will only be using the last line in your ve table which is 105kpa. Unless you hd the values at 100+ you'd obviously be seeing lean there. I ofcourse would of freaked as soon as I saw your tune, but again...my bad. I didn't read into your post.
Fast86z
Aug 23, 2015 12:35 AM
