Sd not seeing commanded PE?
Old Sep 22, 2008 | 06:20 PM
phasemaster1's Avatar
Default Sd not seeing commanded PE?
I disabled my maf to tune ve and now commanded 1.275 pe not doing anything. MY pe tps is at 45% map is at 40kpa 0 rpm delay I thought when pe tables met pe command? Working fine before.
Old Sep 22, 2008 | 06:22 PM
thunder550's Avatar
High on diesel fumes
What program? Are you using a custom operating system? Need more details before we can help....
Old Sep 22, 2008 | 06:37 PM
Im using HPtuners, Im in SD tuning the ve, did wot and went lean ecm never tried to go into pe. I thought pe was automatic command.
Old Sep 22, 2008 | 07:46 PM
dewmanshu's Avatar
Moderately Differentiated
post your tune. it'd be easier just to look at your settings. You sound like you are versed in it though.
Old Sep 22, 2008 | 08:05 PM
KySilverado's Avatar
Is VE tuned in those areas?
Old Sep 22, 2008 | 08:08 PM
03sierraslt's Avatar
If you are not running a 2bar map then dont go into boost when you have the MAF unhooked.!!!!!!!! You are running a MAF tune and have it unhooked to tune the VE correct? If so STAY OUT OF BOOST... Otherwise the PCM doesnt know about the added airflow.
No need to look at the tune.
Old Sep 22, 2008 | 08:22 PM
Thanks pat just tapped it...it was lean
Old Sep 22, 2008 | 08:24 PM
As mentioned above you are 1bar so stay out of boost until the MAF is enabled.
How much boost are you running? Once you get your fueling straighened out some then work on bringing your timing back up some.
Old Sep 22, 2008 | 08:25 PM
When you go 2 bar is that where the boost enrich kicks in?
Old Sep 22, 2008 | 08:30 PM
looks like 7-8psi with the maf enabled afr 11.5-11.3 timing is at 12* for now. Tried to get my ve tuned when I put the centri on could only get as close to 5% so left it.
