SD on a N/A 5.3L?
Old Nov 11, 2007 | 10:36 AM
03sierraslt's Avatar
Personally I would do like 12.6aft at WO for NA, as for Speed Density with your cam it may idle smoother and throttle response should be a tad better.
Old Nov 12, 2007 | 10:16 AM
Compressor Surge's Avatar
I'm running an OL-SD tune on my N/A 5.3 and love it!
I can't say how much different it is than a CL-MAF tune, because I tuned it this way from the start.
Old Nov 12, 2007 | 03:22 PM
zippy's Avatar
Originally Posted by dc_justin
Speed Density does not mean that you're ignoring the oxygen related sensors, it is simply that it uses manifold pressure and RPM to define engine load and not the factory mass air meter. Everything else can be configured just the same.
One of the cons of this setup for 1TrueSS is if this is not done with a custom operating system, then you'll lose the ability to have dual spark tables (High and low octane). If you're overtimed or have a bad tank of gas, you're losing this safety instrument.
I agree, it sounds like someone is confused between speed density and speed density open loop. Both work great if you have alot of time to tune your truck.
Old Nov 12, 2007 | 08:25 PM
regency's Avatar
not confused, just was never told about the open loop style!!!!! and have never read anything about it. i just dont like the point of it i mean they went to a MAF and O2 for a reason right?????
zblee
Nov 11, 2015 12:41 AM
lxcoupe
Oct 4, 2015 08:07 PM
old motorhead
Sep 29, 2015 08:22 PM
