Replacing stock pcm
Old Jun 8, 2006 | 06:28 PM
Default Replacing stock pcm
if i replace the stock pcm do i have to do the crank postion relearn deal. or should everything be ok.
Old Jun 8, 2006 | 07:06 PM
RoninsDenali's Avatar
I'm assuming you're getting a mail-order tune. As thats the only logical reason to replace the PCM heh.
Chances are, you will have to do a crank re-learn. But you'll only know for sure if that DTC shows up.
Old Jun 9, 2006 | 06:20 AM
no i had a mail order and pulled it out. put stock back in and was wondering if i needed to do the crank postion relearn.
Old Jun 9, 2006 | 11:43 AM
Ahh, ok that make sense.
You should be ok, since you are replacing the tuned PCM with your stock PCM. It should still remember your crank position data.
InsaneDomestics
Jul 27, 2015 02:42 PM
chvy=power
Jul 27, 2015 10:06 AM
sauldgold
Jul 23, 2015 02:15 PM
76k10chase
Jul 17, 2015 01:48 PM
