Removing OnStar, does it need ECM retuning?
Old Feb 19, 2014 | 11:30 AM
DarkCharisma's Avatar
Default Removing OnStar, does it need ECM retuning?
There's some weird bug with OnStar in my wife's 2002 Tahoe that will periodically stop it from starting. No power actually gets to the starter, I have lights, chimes and no dip in voltage with the key turned; if I dick with the Onstar buttons or it's fuse it will fire right up.
I did some digging and found a diagram for the VCIM and where all it's various piggies and plugs are, removing it doesn't seem hard but I don't want to brick the truck by removing it if there's some parameter in the ECM that expects to see it.
Thoughts?
Old Feb 19, 2014 | 12:15 PM
TXsilverado's Avatar
connect to onstar and ask them? no clue...
Old Feb 19, 2014 | 02:39 PM
It doesn't work, it's the old analog system not the new digital one.
Old Feb 19, 2014 | 08:55 PM
Suburbazine's Avatar
You can remove Onstar without any issues. I'd disconnect the button panel and disconnect the cell module (unplug the 25 pin connector from right side) that is behind the gauge cluster. The OE radio may have issues if you pull the fuse that feeds Onstar, but if you have an aftermarket radio you can go ahead and pull it.
Old Feb 19, 2014 | 09:33 PM
thunder550's Avatar
High on diesel fumes
If it's like the 03+ radios, you can just unplug the module and everything will be fine.
Old Feb 20, 2014 | 11:27 AM
Cool, thanks for the feedback. I'll remove it this weekend.
Old Feb 20, 2014 | 12:29 PM
bigsapper's Avatar
Hack OnStar
dsbodley
Nov 14, 2015 09:46 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
Wolftrk99
Oct 2, 2015 08:17 AM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
Silver8ado
Sep 30, 2015 11:42 AM
