Reduced Engine Power
Old Oct 13, 2008 | 07:24 PM
viciousknid's Avatar
Where's the Beef?
Default FIXED: Reduced Engine Power
Been doing some tuning while cruising and decided to hit some upper rpms for a change.
Got up to about 5500 or so and triggered "limp mode". Not really sure why.
Posting Log of the run. it's obviously toward the end of the log. And posting the tune I had in.
Trims where off for tuning.
(yes corey, trims are working now).
Maybe I hit PE mode? could that do it?
File Type: tun
File Type: efi
Old Oct 13, 2008 | 08:56 PM
Where's the Beef?
bumpy
Old Oct 13, 2008 | 10:34 PM
southern_chevy's Avatar
I had my truck do that one time. Just checked out my tune and reloaded it and all was good cant really remember what I changed tho. Sucked happened to me one morning headed to work.
Old Oct 13, 2008 | 10:44 PM
truckmann's Avatar
I know why...I know why..
Maybe....Is your MAF still hooked up?
Old Oct 13, 2008 | 10:53 PM
Where's the Beef?
it was shut off for autoVE tuning.
nothing different than any other time. Just this one time it decided to go Limp.
Damn I hate it when that happens.
Old Oct 13, 2008 | 11:05 PM
truckmann's Avatar
If it is just put in fail mode and still plugged in then it is still giving readings, although they aren't being used to control the engine they are still active for diagnostics. Ask me how I know this...
I don't know EFI live but, what I would look for is a table in the Diagnostic section having to do with (Calculated airflow vs. TPS vs. RPM). In HPT the button is called "Calc Airflow-P1514/P0068 error" under TPS in the Diagnostics section.
After you find it raise the values up by 10% and run it for a while. If you don't get limp mode anymore then all good. If you do raise it another 5-10% until you no longer get limp mode. Some people just max this table out, but I don't suggest that as it would completely disable a safety feature.
With the addition of the cam and some tuning you have probably exceeded some of the values in this table which makes the pcm think the TPS is faulty.
Old Oct 14, 2008 | 07:25 PM
Where's the Beef?
I think I figured it out. I triggered it again and got a TPS code, but seems odd. so I loaded my other tune and was able to go all the way.
Compared the two VE tables and the Table that was throwing it into limp mode (tuned with AUTOVE) had set the upper rpms too high. Maybe I went into PE mode during the drive and gave it false readings?
Old Oct 25, 2008 | 10:28 PM
Where's the Beef?
Had Tyler loadCOS3 and do an SD tune but when I hit 5200 RPM I triggered the damn REP again.
after a while of Tyler digging and searching for the problem he finally found a solution on the EFILIVE Forum, while I ate my BBQ Burritos.....mmmmmmmm.
I changed C5501 (MAP Rationality Test RPM HIGH from 5000 to 6500
and added 50% to C6101 (ETC Predicted Airlfow)
Loaded those changes and everything is Hunky Dory.
Old Oct 25, 2008 | 10:33 PM
dirt track racer 81's Avatar
who did the COS3 and AutoVE? I Didnt hear who did that?
Old Oct 25, 2008 | 10:35 PM
Where's the Beef?
It's there..... plain as day.....
