rebuilt lq4 wont start
Old Oct 8, 2012 | 08:18 PM
2005 Silverado's Avatar
SPAM HUNTER
Default rebuilt lq4 wont start
Rebuilt lq4, new bearings and rings. Has spark, fuel, and compression all I get is what sounds like popping in the intake. Tune is stock 6 liter with injector flownrates changed for the marine 8.1s. All grounds are good, battery ground on side of block and ground from harness then 3 on back of motor.
What do you guys think?
Old Oct 8, 2012 | 09:59 PM
SPAM HUNTER
Tried extra pcm no change. Its like its turning backwards.
Old Oct 8, 2012 | 10:04 PM
TXSZ66AVLANCHE's Avatar
I've seen someone do this on a engine swap in a 1971 pickup....battery cables connected backwards on battery. No joke
Old Oct 8, 2012 | 10:21 PM
SPAM HUNTER
They are hooked right visually, I might swap battery's and try it.
Old Oct 8, 2012 | 10:31 PM
2doorfury's Avatar
Timing chain installed correct? Piston at tdc, cam gear and crank gear dots pointing at each other?
Old Oct 8, 2012 | 10:49 PM
SPAM HUNTER
Its all correct. Pulled the front end apart to double check.
Old Oct 8, 2012 | 11:02 PM
2doorfury's Avatar
Try removing pcv valve hose from the top if intake. Mine wouldn't start with it hooked up after i rebuilt it.
Old Oct 8, 2012 | 11:14 PM
SPAM HUNTER
Mines hooked to a catchcan.
Old Oct 8, 2012 | 11:22 PM
2doorfury's Avatar
So its not hooked to the top of intake?
Old Oct 9, 2012 | 02:15 AM
sand man's Avatar
check the EVAP silonoied (poor spiling ) but you know what I mean
