rebuilt lq4 wont start
Old Oct 9, 2012 | 07:57 AM
2005 Silverado's Avatar
SPAM HUNTER
Originally Posted by 2doorfury
So its not hooked to the top of intake?
Nope
Originally Posted by sand man
check the EVAP silonoied (poor spiling ) but you know what I mean
Efi live clicks it.
Old Oct 9, 2012 | 08:02 AM
Nflddog1000's Avatar
Sounds like timing u got any codes, cam sensor
Old Oct 9, 2012 | 09:09 PM
SPAM HUNTER
No codes or well i got a p0315 today. Timing is on I checked it. I taking a rest from it working on my air compressor restoration and 36" lathe clean up.
Old Oct 13, 2012 | 09:00 PM
SPAM HUNTER
Changed out crank and cam sensors no change. Any others have any ideas.
Old Oct 13, 2012 | 09:34 PM
whitedakota's Avatar
I'd say outta time.. But you verified it wasn't. Can't it be 180* or something similar to an old sbc? Cam wise?
Old Oct 14, 2012 | 09:00 PM
SPAM HUNTER
I checked dot to dot. So unless the sensor is reading the cam wrong idk what else to check.
Old Oct 14, 2012 | 09:22 PM
01silvy's Avatar
It deff sounds like the timing is off to me too, but since you verified that then i dont know. Did you turn the engine over by hand before final assembly to make sure everything turned over smooth?
Old Oct 14, 2012 | 09:42 PM
SPAM HUNTER
Sure did. When I installed the rockers spun it to retorque. I guess ill tear it down again.
Old Oct 15, 2012 | 01:51 AM
1FastBrick's Avatar
Custm2500's Rude Friend
Stock cam, lifters, and push rod's???
P0315 is crankshaft variation not learned.
I wonder if there is an issue with thrust / end play or if the crank wheel is damaged.
Did you change/ modify the tune your self??? Are you sure you adjusted everything correctly???
Old Oct 15, 2012 | 09:08 PM
SPAM HUNTER
Comp xr281hr, ls7 lifters, 7.350 comp pushrods. I took the best care of the crank I could. I'm trying to tune it myself.
