RapTR cam Tuning?
Old Dec 10, 2012 | 11:28 PM
smokeshow's Avatar
Mod with training wheels
First thing lol...try changing the engine size in the tune. With a 6.0, the 5.3 values are going to have a tendency to make it go lean when referencing VE. Also, make the rolling idle table match the lowest value in your target idle speed table.
Old Dec 10, 2012 | 11:34 PM
urdone's Avatar
Got it lol im just tired of not making it work, Im trying to make it idle right then go and finish the rest.
Old Dec 10, 2012 | 11:36 PM
oakley6575's Avatar
Dude you are going about it *** backwards. Correct the small stuff, then most of your problems will fall into place.
Old Dec 10, 2012 | 11:40 PM
smokeshow's Avatar
It needs to know how much fuel it needs to give the engine before you can properly tune for smooth idle. Erratic fueling on the low end will have you chasing your tail forever with the idle.
Old Dec 10, 2012 | 11:44 PM
urdone's Avatar
So i should start correcting the fuel first?
Old Dec 10, 2012 | 11:52 PM
smokeshow's Avatar
To be honest, this stage in tuning is a guess for almost all tuners. You can't calibrate fueling unless its at steady state. Obviously with a jumpy idle like that, its anything but steady state. So you sort of have to play with the fueling in the idle cells a little bit to put in the approximate amount of fuel it needs. Once that is more or less smoothed out, you can start working on the idle characteristics. But if its got big swings in fuel delivery, the idle will move around on you as well. I personally tune idle last, unless it won't idle at all. If it idles enough to keep the vehicle on, I take care of all the fueling elsewhere in the rpm/load ranges. Then when its got the fuel it needs, I go back and work on idle characteristics. That's a good start for you.
Old Dec 11, 2012 | 12:04 AM
urdone's Avatar
Ok,
What is the easiest way to calibrate the fuel?
Old Dec 11, 2012 | 12:05 AM
urdone's Avatar
I got my wideband here my plans on this truck was runing it on open loop.
Old Dec 11, 2012 | 12:06 AM
smokeshow's Avatar
Log STFT and AFR error vs your commanded values and make percentage adjustments as necessary. Easier said than done, though.. You might try reading some of the tutorials on the HP Tuners forum.
Old Dec 11, 2012 | 12:12 AM
urdone's Avatar
Thanks appreciated your help.
Yea i have read those tutorials on hptuners but i havent got a problem untill this one, and to its the first big cam i tune.
ARC
57
Feb 21, 2022 10:54 AM
Matt331
Jul 26, 2015 09:40 PM
ssierra08
Jul 15, 2015 06:40 AM
4B11T
Jul 13, 2015 03:48 PM
all_individual
Jul 13, 2015 11:01 AM
