Random Multiple Misfire not stalling right
Old May 31, 2006 | 12:44 AM
dirt track racer 81's Avatar
Default Random Multiple Misfire not stalling right
Ive heard alot about it you have a random misfire codes that your torque converter wont stall correctly?? it really only stalls to about 2000 rpm and it should stall to 3000..what tables do i need to look at in efilive? i have all the MIL's turned off by the way also..should that be it or is there more to it?
Old May 31, 2006 | 09:04 AM
anyone?
Old May 31, 2006 | 09:56 AM
Zick's Avatar
No, a misfire code will only cause your convertor to not lockup. It does not have anything to do with it not stalling up to a desired rpm.
You can try and disable the misfire codes by going into the Engine Diagnostics>Misfire and setting the Max and Min ECT to something high like 265* so it will not read misfires until it reaches that temp.
Old May 31, 2006 | 09:58 AM
white1's Avatar
Yea, what Zick said. I increased the speed where my PCM acknowledges a misfire.
Old May 31, 2006 | 12:24 PM
ok i see thanks for clearing that up..would there be any other reason why this is not stalling to 3000??
Old May 31, 2006 | 01:12 PM
Zick's Avatar
How long have you had it in for?
Old May 31, 2006 | 04:43 PM
been about 2-3 weeks or so..its a tb torque converter restalled to 3000
Old May 31, 2006 | 05:34 PM
Z284thgen's Avatar
11 Second Club
foot brake stall is low or flash stall is low
whats it flash to man
legerwn
56
Nov 15, 2015 10:21 PM
Tydriver
45
Oct 23, 2015 09:19 PM
GM1697
Sep 9, 2015 10:31 PM
CammedZ71
11
Sep 9, 2015 02:05 PM
Brandonlflr12
Sep 8, 2015 09:01 PM
