Random drops in timing, Im scratching my head
Old Jul 29, 2010 | 09:06 PM
Majourlittle's Avatar
I was looking at those wondering what they did and when i disabled the first table, I though i would test that first, then zero out tables until I got the desired results.
I think once its disabled, It doesent matter what it does.
Old Jul 29, 2010 | 09:10 PM
Atomic's Avatar
I have a gauge for that
I mean the settings under system > ac
Old Jul 29, 2010 | 10:03 PM
couldnt someone just zero them out and see if the compressor kicks on?
Old Jul 29, 2010 | 10:19 PM
MikeGyver's Avatar
On my truck the A/C fan settings could not possibly work, I think. That is because as far as I know, the high-side switch in the A/C line is just that, a switch. It opens and closes at a pre-set pressure. The PCM couldn't know the A/C pressures because there is no pressure transducer. Maybe later model trucks, or some car, have transducers instead of switches and control the fans by pressures.
Old Jul 30, 2010 | 02:34 AM
Atomic's Avatar
The PCM does monitor the AC pressure via a 5v sensor to control the ac clutch.
Old Jul 30, 2010 | 09:16 AM
MikeGyver's Avatar
Wouldn't the sensor need three wires?
Old Jul 30, 2010 | 09:20 AM
Atomic's Avatar
No. The wire is red with a black stripe if you want to look for it. You can log AC pressure in efilive/hpt in terms of voltage, knowing the range of the sensor and that its linear, you can calculate the pressure in the system if you really wanted to.
Old Jul 30, 2010 | 09:35 AM
KySilverado's Avatar
There is actually a PID that will give you actual A/C pressure in my 03 OS.
chopperloco
Jul 10, 2016 10:45 PM
Ammadien
Jul 22, 2015 08:50 PM
smit2732
Jul 19, 2015 01:43 PM
4B11T
Jul 13, 2015 03:48 PM
abey15
Jul 13, 2015 02:20 PM
