Question on tune adjustments for O2 Switchpoints not equal to 450mv
Old Sep 22, 2009 | 02:59 PM
BlackGMC's Avatar
Resident Retard
Default Question on tune adjustments for O2 Switchpoints not equal to 450mv
OK i got a question about O2 switch points... On my stock tune my O2 switchpoints were set to 450 across the board which would be roughly 14.68 AFR. I then tuned my airflow tables (VE and MAF) with my wideband to 14.68 in open loop, when i was finished i went back to closed loop fueling and my trims were all +/- 2 which is fine....
I read that lowering the O2 switch points to 350ish will lean the AFR out because the O2 sensors would be osciallating around 350 instead and 450... So i did that, i lowered the values that correspond to the low load area. So then I noticed my trims went positive or negative (I don't exactly remember I have the log at home) by a decent amount and the AFR leaned out like i thought.
Now here is my question:
1. Should i go back and tune my VE and MAF tables with trims to incorporate the O2 switch points to bring the trims back inline?
2. Should i just tune the MAF table with trims because from my understanding the VE table takes over in heavy/quick throttle transitions.
Thanks in advance.
Old Sep 22, 2009 | 06:59 PM
dlt76028's Avatar
e=mc2
but seriously you ask the hardest questions.
Old Sep 23, 2009 | 04:14 PM
ForcedTQ's Avatar
Thumbs up
Excellent question, and I was wondering the exact same thing! Hopefully someone knows the answer and is willing to help out.
Old Sep 23, 2009 | 04:26 PM
BlackGMC's Avatar
Resident Retard
I believe I know the answer I just want someone more experienced and smarter than me to comment..
Old Sep 23, 2009 | 06:12 PM
hirdlej's Avatar
Corey, you have a PM
Old Sep 23, 2009 | 06:15 PM
dlt76028's Avatar
I already did corey
Old Oct 11, 2009 | 10:25 PM
dc_justin's Avatar
Hello Dave
You do not want to re-tune your VE and MAF tables. VE and MAF describe air mass, which is not changing.
03chevytruck
Nov 7, 2016 04:43 PM
mrhino
Aug 7, 2015 10:01 AM
BlackGMC
Oct 25, 2007 03:07 PM
BenKey
Apr 22, 2004 10:24 PM
