Pulls timing at random...
Old May 24, 2016 | 09:26 AM
Mark Johnson's Avatar
Default Pulls timing at random...
Like the title says- doesn't really happen in specific places like grade or hills but have observed happening anywhere between 45 and 60% throttle it pulls like 35*, almost as if it thinks it's about to shift. Anyone had an issue like this can tell me where to look, thanks.............
Old May 24, 2016 | 09:38 AM
madmann26's Avatar
torque management on the tranny.
Attached Thumbnails Pulls timing at random...-2016-05-24-10_38_50-vcm-editor.png
Old May 24, 2016 | 09:41 AM
But isn't it supposed to know when to manage the torque/ pull timing?
Old May 24, 2016 | 09:46 AM
madmann26's Avatar
It does what the PCM tells it to do, in this case, pulls timing. That table I screen capped shows what you need to change/update. Keep in mind, a little TM (torque management) is ok.
Old May 24, 2016 | 10:53 AM
Thanks- i'll check everything out when I get home........
Old May 24, 2016 | 11:42 AM
Gadgetized's Avatar
This could also be caused by the AC. See if this happens when the AC is turned off.
Old May 24, 2016 | 01:06 PM
Does seem to happen more often with A/C on, but I'll check the cells in the tune when I get home. Scn1.hpl
Old May 25, 2016 | 09:02 AM
No changes, guys. I addressed the cells in the table I did have values in some of the other cells. I'll attach my tune and a scan.......
File Type: hpt
File Type: hpl
Old May 26, 2016 | 09:45 AM
K guys- problem solved, I replicated the values in the cells you pictured, mad. Still feels a little sticky though
Old May 26, 2016 | 12:15 PM
FFDP's Avatar
Man that thing knocks like crazy, I think you are running way too much timing in that thing.
