problems with HPT 2.0
Originally Posted by Wilde Racing
No did you remove the old 1.7/1.6 version before the install? It does take a few tries to get it recognize my cable though.
How do I change this text
did you update frame work to 1.1 like dewmanshu said? maybe try loading the old version and updating it to the 2.0? Even thou HPTuner tells you to uninstall it. I did not as well and it worked O.K for me, just the short cuts had to be updated.
What does it do? is it in the ADD/REMOVE programs after you install it 02sierraz71_5.3?
Here is the crack
Microsoft "Genuine Advantage" cracked in 24h: window.g_sDisableWGACheck='all'
AV sez, "This week, Microsoft started requiring users to verifiy their serial number before using Windows Update. This effort to force users to either buy XP or tell them where you got the illegal copy is called 'Genuine Advantage.' It was cracked within 24 hours."
Before pressing 'Custom' or 'Express' buttons paste this text to the address bar and press enter:
javascript:void(window.g_sDisableWGACheck='all')
It turns off the trigger for the key check.
Originally Posted by Toaders
Here is the crack
but it doesnt work for any of the service packs
I was not sure if they figured it out yet that crack has been around for a while. Another thing you could do is if you know someone with a valid license they have an option to manually authenticate. You install some software it gives you a 5 or 6 digit code for validation. Just use his code on your PC. Good luck
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
