problems with HPT 2.0
Old Nov 2, 2005 | 08:34 PM
02sierraz71_5.3's Avatar
Default problems with HPT 2.0
Anyone having installation problems with HPT 2.0?
Old Nov 2, 2005 | 08:37 PM
Wilde Racing's Avatar
How do I change this text
No did you remove the old 1.7/1.6 version before the install? It does take a few tries to get it recognize my cable though.
Old Nov 2, 2005 | 08:47 PM
dewmanshu's Avatar
Moderately Differentiated
I didn't remove the old 1.7 version and my 2.0 works fine except the scanner...the histogram only works in the first column (400 rpm). I kinda haven't bothered with it because I am okay with the old scanner. It's the edit program I care about....I didn't have any installation problems. Did you load Microsofts .NET? Reload that as well if you continue to have problems, sometimes it clears **** up.
Old Nov 2, 2005 | 10:40 PM
I uninstalled the old and installed .net I cant get a response from hp tuners
Old Nov 3, 2005 | 09:21 AM
did you update frame work to 1.1 like dewmanshu said? maybe try loading the old version and updating it to the 2.0? Even thou HPTuner tells you to uninstall it. I did not as well and it worked O.K for me, just the short cuts had to be updated.
What does it do? is it in the ADD/REMOVE programs after you install it 02sierraz71_5.3?
Old Nov 3, 2005 | 09:41 AM
Ive tried all of it the only thing I can figure is that my copy of xp is illegal and its not completely installing .net correctly anyone know a fix where I can fool windows into not checking registration I might have to install the service packs also.
Old Nov 3, 2005 | 09:53 AM
Toaders's Avatar
Here is the crack
Microsoft "Genuine Advantage" cracked in 24h: window.g_sDisableWGACheck='all'
AV sez, "This week, Microsoft started requiring users to verifiy their serial number before using Windows Update. This effort to force users to either buy XP or tell them where you got the illegal copy is called 'Genuine Advantage.' It was cracked within 24 hours."
Before pressing 'Custom' or 'Express' buttons paste this text to the address bar and press enter:
javascript:void(window.g_sDisableWGACheck='all')
It turns off the trigger for the key check.
Old Nov 3, 2005 | 11:09 AM
Originally Posted by Toaders
Here is the crack
reinstalled .net with the update crack
but it doesnt work for any of the service packs
Old Nov 3, 2005 | 11:38 AM
Toaders's Avatar
I was not sure if they figured it out yet that crack has been around for a while. Another thing you could do is if you know someone with a valid license they have an option to manually authenticate. You install some software it gives you a 5 or 6 digit code for validation. Just use his code on your PC. Good luck
Old Nov 3, 2005 | 12:14 PM
thanks for the help
madmann26
Apr 29, 2020 09:17 AM
dsbodley
Nov 14, 2015 09:46 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
sTNT971
Sep 26, 2015 06:27 AM
