Problems after long tube install
Old Jul 16, 2010 | 06:37 PM
nickleahy23's Avatar
Originally Posted by fastrt
get some oem o2's. you need to tune for them or they will make you run rich too.
so im fucked out 170 bucks? they were like 79 a piece lol...i could try saying they made it run like **** blablabla and see what orielys says..normally they wont take anything electrical back if its been hooked up..
i mean, since the once i have now are new, and im going to be doing the scan retune with justin, can i just let him know what i have for o2s and he can tune for them? he should be able to see how they are reading and adjust from there correct?
here is what i have..when i checked all the stores around town, they all gave me the same part number for what was most popular/worked the best
http://www.oreillyauto.com/site/c/de...2205&ppt=C0018
Old Jul 16, 2010 | 09:15 PM
rel3rd's Avatar
11 Second Club
The tune needs re-tweaking when you add headers, especially with an off road Y. Not the same fueling requirements of stock manifolds and cats, for sure.
Think about it, the exhaust flow isn't even comparable to how it was stock, and the O2's are moved a foot or so further back in the exhaust, so naturally even if they happened to read the same as stock, they'd be giving false, or incorrect, feedback. How can the present tune compensate, if it's "tuned" for a different setup? If you change the way an engine breathes, you need to have the tune tweaked for best efficiency and results. Will cars/trucks run fine usually after a header swap? Sure. Will they run their best as-is? Absolutely not.
I assume you're referring to doing some sort of a datalogging scan? If so, your tuner will know what needs to be done/changed.
FWIW, I run those exact same Bosch O2's in my truck (Since November 2009). I got a slow response code very intermittently (due to the sensor placement in the headers), just like with the stock O2's, which was easily "tuned" out.
Old Jul 16, 2010 | 11:43 PM
fastrt's Avatar
11 Second Truck Club
if they are new o2's then run them. but i stick to OEM. only cause I am a tech at a dealer, and getem at cost plus 10%.
Old Jul 17, 2010 | 05:07 PM
TX Tahoe Z71's Avatar
Just curious, what is cost on the o2's? Shoot me a pm if you don't want to post up here, or if that's none of my business, no worries, haha
Old Jul 17, 2010 | 10:35 PM
00_Hotrod's Avatar
When i installed my LT's i found the engine went lean, I Assumed because of the scaveging on the cylinders, And after I retuned it the HP came in good, When the 02's see a lean condition it will cause the fuel system to richen and fuel mileage to go down, get it retuned and you'll be good..
rednekferlife101
32
Jan 8, 2016 10:42 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
Suburban2500
Jul 13, 2015 09:57 AM
Deceptarado
Jul 8, 2015 05:24 PM
supersportsteve
Jul 4, 2015 12:02 PM
