Possible Lingenfelter TRG-002 fail
Old May 12, 2018 | 04:15 PM
meatwad's Avatar
Fast lane preferred
Default Possible Lingenfelter TRG-002 fail
Truck is a daily driven 2003 silverado SS.
Did a ly6 swap in 2011 when the original lq9 took a dump. Shop that did the install used the trg-002 to use my pcm and avoid having to swap the 58x reluctor wheel. Functioned flawlessly until recently. Engine dies while cruising intermittently, more often when ambient temp is higher. Also has trouble starting at times. No error lights on the trg-002. I cannot reproduce a stall while idling.
What i I have tried so far:
-dealer checked and found no codes
-inspected wires-found some wear with exposed wire on the crank out near the trg box, covered that with electrical tape. Loom near the crank sensor wire fell apart in my hands. Wires intact. New loom added. There is heat sheiding between this wire and the headers.
-Replaced the crank sensor cuz it was cheap and easy
-fuel pump relay looks good by visual inspection, no scorching
No change in issues after the above. Before I throw more parts at it, I wanted to get some input. I checked over on ls1tech and some of the early versions had heat issues. Possible mine is failing due to age and/or the wiring is failing due to the elements.
I can can try replacing the cam sensor, but I suspect I will end up replacing the trg itself unless there is some other possible issue.
Thanks in advance,
Nate
Old May 13, 2018 | 10:42 AM
turboal1's Avatar
Default Lng
Did you call them ? I would
Old May 13, 2018 | 12:03 PM
meatwad's Avatar
Fast lane preferred
I plan on calling them for guidance. Work blew up on me and I ran out of time last week.
Old May 14, 2018 | 07:05 PM
meatwad's Avatar
Fast lane preferred
Lingenfelter suggested replacement due to age and problems I described. I forgot to ask if one has run for as long as mine had.
They did offer to test my box for free and send it back to me if it still works.
Old May 17, 2018 | 05:48 PM
meatwad's Avatar
Fast lane preferred
Found the issue. Wires from the crank sensor got cooked. The loom was actually melted to the wires inside. Between the tranny rebuild and adding long tubes the wires were way to close to the headers. Heat shield was on there but not enough apparently. New box installed and I routed the wires a little better with more heat shield material.
Old May 20, 2018 | 09:23 AM
turboal1's Avatar
Default Box
Was the box bad ?
Old Jun 17, 2018 | 01:08 PM
meatwad's Avatar
Fast lane preferred
I don’t think so. Since I already purchased and installed the new one I am going to keep it for a back up. I would have to redo the crank in wire through.
Still working great since the install. Wires are looking good with the new position.
Old Mar 5, 2022 | 05:57 AM
lsx tahoe's Avatar
Registered User
[QUOTE=meatwad;5439518]
[/QUOTE
Hey I have a 2004 tahoe with a 6.0 swap has a 58 reluctor x4 so I got the TRG-002 module truck turns On but when getting warm reaching to regular running temperature and I shut off the truck it won’t turn back on have to wait 30 mins to 1 hr to cool down and will fire right back up
Old Aug 6, 2022 | 02:37 PM
penuri's Avatar
Registered User
Default Same issue
[QUOTE=lsx tahoe;5508789]
[/QUOTE
hello man how did you fix this problem? I’m having that issue right now
Old Aug 7, 2022 | 01:02 PM
meatwad's Avatar
Fast lane preferred
All I can say referencing what happened to mine, would be to visually inspect the wiring to the crank sensor and cam sensor. Mine were too damaged to save and I did not feel comfortable soldering new wires to the box, so I bought a new one and ran the wiring differently.
adams2003
Apr 23, 2018 09:13 PM
arthursc2
Feb 3, 2017 01:56 PM
chvy=power
Nov 2, 2016 05:39 AM
chvy=power
Oct 30, 2016 01:12 PM
chvy=power
Sep 8, 2015 10:59 AM
