PO342 cam signal code that will not go away no matter what
Old Nov 20, 2015 | 08:56 AM
Roach Coach's Avatar
Default PO342 cam signal code that will not go away no matter what
Anyone ever get a PO342 (cam signal low) code that won't go away no matter what?? It's on an 04 Chevy 3500 with an LQ4.
So far we have:
1. Changed the cam sensor
2.Ohmed the wires from PCM to CMP
3.swapped in another PCM
4. Changed plug for cam sensor
5.put a bore scope down cam sensor hole to check the cam reluctor
6. Put ANOTHER cam sensor in.
7. Tested the wiring and watch the signal counter on the scan tool to verify everything is working after the sensor.
We are at a loss with this truck and it runs great it just doesn't start for **** when it's warm. It'll have a little backfire when you try to start it like its out of time. Any help is appreciated!
Old Nov 20, 2015 | 11:23 AM
907rs's Avatar
DTC P0342 Camshaft Position (CMP) Sensor Circuit Low Voltage
Old Nov 20, 2015 | 12:39 PM
i did those tests already and nothing helped.. ive even ran new wires from the PCM to the cam sensor plug
Old Nov 20, 2015 | 10:28 PM
Have you tried a new cam sensor connector. I had one kick my *** a few years ago only to find a bad connector. The pins lost tension where it mates to the CPS terminals inside the cam sensor. When it was connected to sensor it had a poor connection then and only then. You could ohm it all day change pcms it all checked good.
Is the truck all stock and did it just start doing one day out of the blue.
BLKSSLTT
Mar 20, 2016 03:39 AM
Gorske
Oct 23, 2015 07:46 AM
mhorn0817
Oct 17, 2015 06:58 AM
Lthompson
Sep 21, 2015 07:06 PM
Go5.3tt06
Sep 14, 2015 02:11 PM
