Dbw to dbc tuning
Old Nov 20, 2015 | 08:28 PM
kent91011's Avatar
Default Dbw to dbc tuning
What all needs to be changed in the tune. I have turned the 1 to 0 in the system tap system options etc. it will start if I give it gas but will not idle. I have confirmed that the iac motor is not working. I have no dtc I have followed lt1 swap to the T I have the correct pcm and triple checked the wiring any help would be great thanks
Old Nov 20, 2015 | 08:38 PM
Atomic's Avatar
I have a gauge for that
Are you using the same PCM? You need to get one from a DBC truck...
The harness is slightly different as well I believe
Old Nov 20, 2015 | 08:42 PM
kent91011's Avatar
Yeah I have an 03 with the pcm capable of controlling the iac
Old Nov 20, 2015 | 09:32 PM
Atomic's Avatar
So what year pcm were you using originally?
Old Nov 20, 2015 | 09:45 PM
Vortec350ss's Avatar
I've been debating this swap myself... In for info and results.
Old Nov 20, 2015 | 11:52 PM
GMCtrk's Avatar
Could always get a PCM out of a van
Old Nov 21, 2015 | 12:38 AM
The PCM is the same from van to truck. Find a vin for a van and flash the pcm to that VIN. Now depending on what this is in it could cause other potential problems with certain accessories on the vehicle not functioning etc but you just weed those out one at a time after that IE ABS cruise control etc.
Old Nov 21, 2015 | 12:41 AM
1FastBrick's Avatar
Custm2500's Rude Friend
Simply changing it in the tune will not work.
You will need to use an OS for the year of the vehicle that was Drive by cable.
As mentioned, The Express Vans used a cable driven throttle body. You also need to be sure the PCM is capable of supporting it.
As far as the harness I believe the same wires are used on the Drive by Wire Vs. Drive by cable and you can repin with correct connectors to make it work. Should verify the PCM side of the wiring to be 100% sure though.
Old Nov 21, 2015 | 07:53 AM
kent91011's Avatar
Anyone have a 03 express van file?
Old Nov 21, 2015 | 08:03 AM
03sierraslt's Avatar
I've been pondering this option also.
