PCM read trans and engine oil temp?
Old Sep 13, 2005 | 09:46 AM
FS560's Avatar
Default PCM read trans and engine oil temp?
If the PCM reads transmission temperature, where is the sensor located?
Does the PCM also read engine oil temperature?
Old Sep 13, 2005 | 08:05 PM
bigredexpress99's Avatar
If I remember correctly from rebuilding my last 4L, its in the pan, just onder the filter. Dont quote me, that was almost 6 months ago. I think its basically a resistor thats chilling in the fluid.
Old Sep 13, 2005 | 08:46 PM
The temp sensor for the tranny is on the valve body, i think. As far as i know only corvettes came with oil temp sensors.
Old Sep 13, 2005 | 09:05 PM
FS560's Avatar
Then with the temperature sensor in the pan at the valve body, the fluid leaving the converter could be at a significantly higher temperature.
Has anyone ever checked the temperature at the inlet to the cooler?
Old Sep 14, 2005 | 08:31 AM
Gordy M's Avatar
Don't the Denali's have a temp sensor on the dash...lower left if I remember correctly. I am told the Yukon came with the wiring but not the guage..never looked to confirm it.
Old Sep 14, 2005 | 01:44 PM
budhayes3's Avatar
PT's Slowest Truck
Yea the Denali's have the temp guage in the lower left of the instrument cluster (also has a 120mph speedo)
ferrellrooster
Mar 6, 2025 03:22 PM
ullose272
Aug 5, 2016 02:05 PM
Noah Burns
Sep 7, 2015 05:50 PM
ullose272
11
Jul 17, 2015 07:22 AM
Nimoryan
Jul 5, 2015 03:50 PM
