PCM Question
Old Apr 27, 2011 | 11:32 AM
1badblazer's Avatar
Default PCM Question
My 2000 silverado that is a 4.3 truck I started pulling the engine and noticed the pcm has four plugs and is black. I thought they were the same physically as the v8 pcm? I have a harness on the way from a 2000 2500hd 2wd truck so I guess I need to get a pcm now that will work with it, is there a certain year pcm I should look for?
Old Apr 27, 2011 | 11:37 AM
nonnieselman's Avatar
What engine are you puttin in the truck? im guessing a v8 since your using the harness from a 2000 2500HD?
Your gonna need a LS1 Pcm.
Old Apr 27, 2011 | 11:45 AM
1badblazer's Avatar
6.0 and 4l80, Could I just get a PCM from a v8 silverado like the one that was in the truck my harness came from? I remember hearing an 02 pcm is a good place to start, it has a better OS?
Old Apr 27, 2011 | 12:13 PM
Yea.. but any 99-02 PCM will work.. you tune or gonna get it tuned to take care of the VATS?
If you get any of the PCMs you can do a OS change to use the 2002 12212156 OS
Old Apr 27, 2011 | 12:23 PM
1badblazer's Avatar
Yea I have hp tuners I was just gonna just do it to my pcm from the truck but come to find out I guess the v6 ones are different. Now I need a pcm.
Old Apr 27, 2011 | 12:31 PM
oh ok.. yea you should be fine then..
check the junkyards, usually you can score one for $75 or so
Old Apr 27, 2011 | 01:55 PM
1badblazer's Avatar
Yea I'm gonna look around and I'll post it up on here also that I need one
blownss27
Aug 14, 2020 08:27 AM
Cowboy Tom
Sep 5, 2015 04:29 PM
Alco
Sep 4, 2015 04:08 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
USMCvet0311
Aug 1, 2015 07:45 AM
