PCM pin assignments?
Old Jun 7, 2006 | 10:50 PM
TurboGibbs's Avatar
Default PCM pin assignments?
I have found them for the 98-02 F-body's on ls2.com but no info for our trucks. Anyone have this information? Especially for 2005?
Old Jun 8, 2006 | 12:21 AM
1slowsilverado's Avatar
What Pinout are you looking for? I dont have a way to post a pic, But have them in front of me....
Old Jun 8, 2006 | 06:07 AM
TurboGibbs's Avatar
Particularly the bank2 sensor 1 wires. I have a problem with bank 2 being consistantly more rich and reading richer. Also I have burnt up 3 sensors in that location. It is 3 times as slow to warm up and start switching than the bank 1 sensor even after I swap them. Figure I have a resistance problem somewhere.
Old Jun 8, 2006 | 07:23 AM
Grumpy5.3's Avatar
Hey MJ,
In the blue connector, pin 26 is th elow signal
pin 66 is the high signal
pin 74 in the green connector is light green, and is the heater circuit for bank 2 sensor 1
Old Jun 8, 2006 | 07:26 AM
TurboGibbs's Avatar
Originally Posted by Grumpy4.8
Hey MJ,
Thanks.
Old Jun 8, 2006 | 07:34 AM
dewmanshu's Avatar
Moderately Differentiated
be careful, I fixed this on mine. The 2000 was a common ground h02. My new 2002 set is low reference and high reference.
Old Jun 8, 2006 | 07:55 AM
TurboGibbs's Avatar
English por favor. I'm unfamiliar with the high and low references.
Old Jun 8, 2006 | 07:59 AM
TurboGibbs's Avatar
Ok. what are the bank1 so I have something to reference to? Also, where do you guys get this info?
Old Jun 8, 2006 | 08:02 AM
dewmanshu's Avatar
just glancing at grumpy's post I didn't see what year he was referencing (his vehicle year isn't in his sig). I have a 2000. My heater and 02 signal grounds are (were) case grounded. The 2002 isn't. Just consider my posts in this thread useless as I KEEP forgetting you are an 05 and I am sure grumpy hooked you up with the right pins because he says..."In the blue connector, pin 26 is the low signal". Not case grounded.
Carry on. LOL
Old Jun 8, 2006 | 08:15 AM
TurboGibbs's Avatar
Carry on. LOL
You said you "fixed it" on yours....what was the problem?
