PCM Location
I dont have a pic but if u look at the engine and then right next to the battery on the left, there will be a little plastic box. That is the PCM, all you have to do is look and there is two tabs that you have to pull the black box around. once u do that there is a metal clip and all you do with that is pop it off. Then undo the PCM wires with i belive is a 7 mm. There should be two of them. Once you do that just slide the PCM out and then reinstall the new one in reverse. its really easy, shouldnt take you longer than 5 mins max.
In the middle pic, look a the purple connector, then look down a tad and you see a large black plastic cover (the one under the radiator hose, right next to the battery). If you remove the cover you will expose the PCM.
Here, I circled the cover in green. The PCM is underneath. There are two little tabs you have to release to get the cover off. The PCM is a big metal silver-gray box with two long skinny connectors coming out the side. Each connector has a 7mm hex head bolt holding it in.
And what all is need to take it off/ replace it?
