P1638 Generator F Terminal Circuit...
Old Jun 23, 2006 | 10:24 PM
01Blackerado's Avatar
Default P1638 Generator F Terminal Circuit...
This is my code...what the heck could this be cause by?? I did switch to a new Alt. 200amp actually. But I hooked it up exactly how the original was and now I get this code. The reason I switch is because I went with a ASP underdrive pulley and I need more amperage!!!
Old Jun 23, 2006 | 11:28 PM
chrisj6's Avatar
Switching to that Alt is what its caused by, just go in and delete the code, wont hurt a thing!
Chris
Old Jun 24, 2006 | 02:30 AM
thunder550's Avatar
High on diesel fumes
Your stock alternator is a 3-wire. 1 for battery hookup (charging post), one to turn the alt on (L terminal), and one for the PCM to sense alt output/load (F terminal). Your new alt is probably a 2-wire, just the output post and the L terminal. The PCM is not seeing a signal on the F terminal circuit like it wants, so it is freaking out. Like chrisj6 said, just disable the code in the tune and you'll be fine.
Old Jun 24, 2006 | 04:23 PM
Nice thanks again chris you come through everytime
Thanks also chrisj6. I appreciate the response times
slowmo934
Sep 9, 2015 12:24 PM
jrplz
Jul 9, 2015 12:07 AM
mjgjr72
Aug 4, 2005 08:39 PM
creederado
Oct 8, 2004 09:37 AM
