P0430 Catalyst System Low Efficiency Bank 2 HELP
i have a 2000 silverado 1500 with a 5.3l 4x4 i have a P0430 Catalyst System Low Efficiency Bank 2 code and i am not able to pass emissions in washington state i have replaced the downstream o2 on the right side and now have replaced my cats with Walker Direct Fit Catalytic Converter from summit racing and i am still having this issue any help would be greatly appriciated i have done all the work myself and am lost the only other thing i can think of is the upstream on bank 2 is bad as well any help would be greatly appriciated as i am running out of options myself.
I dont think the upstream has anything to do with the catalyst monitoring system. The back o2 sensor looks for a flat signal unlike the upstream sensor which is constantly switching from high to low. If you monitor the downstream sensors and they have a switchrate similair to the fronts, the cats are usually burnt out.
i didnt think the upstreams had anything to do with it either but i am open to any ideas its atleast worth it to test it and make sure its ok but i have replaced the cats and the passenger down stream and still no luck
FlowmasterMufflers
Oct 26, 2015 06:19 PM
Fast86z
Aug 23, 2015 12:35 AM
05GMC4.8
Aug 7, 2015 09:55 PM
FlowmasterMufflers
Jul 22, 2015 01:29 PM
