P0430 Catalyst System Low Efficiency Bank 2 HELP
Old Feb 3, 2012 | 04:57 PM
kcmiddle's Avatar
Default P0430 Catalyst System Low Efficiency Bank 2 HELP
i have a 2000 silverado 1500 with a 5.3l 4x4 i have a P0430 Catalyst System Low Efficiency Bank 2 code and i am not able to pass emissions in washington state i have replaced the downstream o2 on the right side and now have replaced my cats with Walker Direct Fit Catalytic Converter from summit racing and i am still having this issue any help would be greatly appriciated i have done all the work myself and am lost the only other thing i can think of is the upstream on bank 2 is bad as well any help would be greatly appriciated as i am running out of options myself.
Old Feb 3, 2012 | 09:40 PM
kcmiddle's Avatar
my truck has 141k on it any ideas?
Old Feb 3, 2012 | 11:49 PM
Suburbazine's Avatar
Tune it out?
Old Feb 4, 2012 | 01:30 AM
kcmiddle's Avatar
if i tune it out will it be able to pass emissions? wont they be able to tell when they plug in the OBDii?
Old Feb 4, 2012 | 02:10 AM
greasemykey's Avatar
it is the upstream O2 sensor that is your problem.
Old Feb 4, 2012 | 02:53 AM
kcmiddle's Avatar
everything i have read and the mechanic i talked to all pointed to the downstream and cats any info you have that would make the upstream the culprit would be appriciated
Old Feb 4, 2012 | 12:16 PM
livefast1's Avatar
I dont think the upstream has anything to do with the catalyst monitoring system. The back o2 sensor looks for a flat signal unlike the upstream sensor which is constantly switching from high to low. If you monitor the downstream sensors and they have a switchrate similair to the fronts, the cats are usually burnt out.
Old Feb 4, 2012 | 12:42 PM
kcmiddle's Avatar
i didnt think the upstreams had anything to do with it either but i am open to any ideas its atleast worth it to test it and make sure its ok but i have replaced the cats and the passenger down stream and still no luck
Old Feb 4, 2012 | 03:41 PM
livefast1's Avatar
Switch the passenger downstream you replaced with the driver side, clear the code and make sure you didnt get a bad sensor.
Old Feb 4, 2012 | 06:36 PM
kcmiddle's Avatar
ill try that next thanks
FlowmasterMufflers
Oct 26, 2015 06:19 PM
lxcoupe
Aug 24, 2015 08:16 PM
Fast86z
Aug 23, 2015 12:35 AM
05GMC4.8
Aug 7, 2015 09:55 PM
FlowmasterMufflers
Jul 22, 2015 01:29 PM
