P0300 code?
I keep getting the P0300 code but only when I'm idleing. I have the POS Bosch+4
(I didn't know at the time). I was wondering, can these be the cause. I know if one is cracked it can but what about a "good" one? I know there are other things I can check also but I felt I should start here.
Multiple misfire code, could be a number of things. I'd lose the Bosch plugs just for piece of mind and start from there. You can pick up a set of NGK TR55's for less than $2 a plug.
I picked up some TR55s earlier this morning. If I have time this afternoon, I'll change them out. If not, I'll do it tomorrow when I change my front wheel hub
Thanks for the help. I hope it works.
For the crank relearn, I hooked up EFI Live to his truck and performed it last summer.
I've had a pretty bad misfire at idle on all cylinders caused by the truck going lean randomly. Think I tracked mine to one of my intake tubing clamps not being completely tightened down.
Tydriver
45
Oct 23, 2015 09:19 PM
