P0011 - Camshaft Position Timing - Over Advanced
I just installed the Mast Motorsports L92 cam, and I knew deep down the mechanics over in Kuwait would **** it up!
I'me getthing the code as mentioned above, and with a lobe of 116, the denali runs rough at idle... I've tuned it so it's not so sloppy but I know something else is wrong with it...
Any ideas if it is a mechanical mistake?
Thanks
Bader
Thanks
Bader
the mechanic thinks he did the cam perfect.. the problem is my arabic isn't as good to explain to him what off a tooth means :S
should i just let him take the timing covers off, pull the chain and actully time it properly again?
just took the denali to anothr shop, he told me it was off by one tooth.. funny thing is though is that he supposedly timed it right and I ended up with the same shitty idle and same code?
Any idea if this could be something to do with the VVT gear?
tweeder
Sep 18, 2015 11:02 PM
atxlt
Jul 20, 2015 11:06 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
