open loop maf tuning
Alright. What do you set the IFR to? As in the 0kpa value or the 80kpa value. I found a calculator online by redhardsupra to find those values. Fuel pressure read 55psi at the rails with the vacuum line unplugged. I'll check the other values as soon as I can get the part number off the injectors.
No problem, ideally you want to also adjust the IPW voltage adjustment and small pulse adjust tables as well. Post up when you figure out what injectors your tuning and I'll help you out if I have the data for them.
noproblems209
08-10-2015 06:57 PM
