Oil pressure...gauge to worky :/
Old Dec 3, 2009 | 10:48 PM
AV8R27's Avatar
Default Oil pressure...gauge to worky :/
On my way home from Houston tonight, about 5 or so miles up the road, I noticed that the oil pressure gauge was reading at around the 80psi mark. Put the truck in neutral for a few seconds to let the RPM's drop down to see if it changed anything. No joy. Went ahead and pulled over, shut it down, started it back up and ended up with the same results. Thing is I know I have good OP, temp stays right where its supposed to. And when I cut the ignition off and back on, the needle went to ZERO with no power, ignition back on 80psi, start sequence back to ZERO and back to 80psi right off the bat.
So; oil pressure sending unit perhaps? I don't think I'm having an issue with the gauge cluster as the needle does "exercise" back and forth. Any and all input would be greatly appreciated. Getting ready to make a trek up to Colorado to do some snowboarding at the end of the month and need my baby in perfect working order. Thanks much!!!
Old Dec 4, 2009 | 12:19 AM
Dewey's Avatar
all i can say is check for codes.
Old Dec 4, 2009 | 01:05 AM
AV8R27's Avatar
No check engine light. So there SHOULDN'T be any codes thrown...
Anyone else??
Old Dec 4, 2009 | 02:37 AM
2005 Silverado's Avatar
SPAM HUNTER
I would say sending unit. If a gauge goes bad normally it wont go to zero when you shut key off. Or atleast when a tach quits it doesn't reset right.
Old Dec 5, 2009 | 11:45 AM
texasbullseye89's Avatar
I'm guessing the sending unit. coworkers camaro was doing the same thing. replaced it and it was fixed.
Old Dec 5, 2009 | 12:08 PM
Mine did that and it was just the pressure switch. I have heard this several times and it has just been the switch. I would start there.
Old Dec 5, 2009 | 05:12 PM
AV8R27's Avatar
Alrighty, went down and picked up an "oil pressure switch". $40 later...and I'll know something on Monday when it goes in. Glad my logic has matched up with everyone else's thus far...
Old Jan 9, 2010 | 12:20 PM
AV8R27's Avatar
Default UPDATE: I did this several weeks ago, and forgot to post up
Ended up being the oil pressure "switch" (sending unit). $40 part, but kind of a PITA to get to. It's right behind the intake manifold on the block, drivers side. Make sure you have a 1 1/16" DEEP socket before you take on the replacement. A small mirror and plenty of light would make things easier...I did everything by FEEL..., lmao.
Old Jan 9, 2010 | 01:40 PM
Mort's Avatar
Good going...that sending unit is a pain to get to.
Old Feb 3, 2010 | 12:08 PM
hobbesnmina2001's Avatar
I recently bought a 2002 Z06 and found out Vettes are known for this type of problem. We had just bought our Vette in SC with only 8300 original miles and 2 hours down the road we stopped and when we restarted the car the oil pressure went to 0#!
I had checked the levels and the engine sounded great, to be sure we took it to a Chevy dealer and they doubled checked by putting on a mechanical gauge via a filter sandwich adapter.
My theory is the OP switches fail probably due to heat and specially in Vettes it's a pain to get to as the back of the manifold is under the cowl but that area also retains a lot of heat.
We used a TPE relocation kit which puts the pressure switch by the harmonic balancer. Since our kit they have a newer version that puts it above the filter with a new made adapter. Other guys on the Vette forum use an extension for an oil pressure gauge and place it on the intake manifold within easy reach, so there are various ways of making this easier to fix next time.
http://www.totalperformanceengineeri...2ac46643d6bb33
some Vette owners also set up an oil port extension by using a flex plastic or copper (copper is safer) oil pressure gauge line and put the sensor on the intake manifold.
Carlos
lukn4trbl355
Oct 21, 2015 11:19 PM
sTNT971
Sep 26, 2015 04:22 PM
lxcoupe
Sep 25, 2015 12:36 PM
69z-28
Sep 21, 2015 07:31 AM
Velocity1
Sep 15, 2015 11:29 PM
