o2 sensor codes
Did you get coated headers? The heater and switching codes will be the typical codes you get on a header swap. Hotter o2's sometimes works or just telling pcm to ignore codes is the usually the best route. The coated or wrapped headers help keep the heat in the pipes which is what the o2's are looking for and if they aren't hot enough they get a little lazy (hence the codes). The sims are only for the rear sensors, they are getting harder to find these days (the sims).
GreenTurtle, What codes are you getting? Sensors 1 or 2?
Sensors 2 just need shut off and Sensors 1 you would do as Dewey suggested and put hotter sensors in (usually off of a vette or F body).
If you already got it tuned and still getting codes for the front ones, it's because your front o2's are taking a longer time to heat up and start switching.. This happens pretty often when you install lt headers... Take it to your tuner and have him check to see if they are switching.. If this the case, just have him disable the SES light for those particular codes....
There is no such thing as a "Hotter" O2 sensor. Precat sensors determine the air fuel ratio of the engine. Post cat tells the computer if the catalytic converter is working properly. Each sensor has a heater circuit to get it to operating temperature quickly. When these sensors are moved downstream (farther from the motor) they may not get to the right temperature fast enough or at all. Another problem with long tube headers. There are several codes for O2 sensors. What do you have?
What brand are we talkin?
Tydriver
45
Oct 23, 2015 09:19 PM
creekrat
Sep 10, 2015 12:59 AM
muncie21
Sep 7, 2015 09:55 PM
