No start, What am I missing?
Old Jul 8, 2013 | 07:01 PM
MOTTRHED's Avatar
MASS seller approved
Default No start, What am I missing?
Ok, bought a 03 sierra 2500 6.0 a week ago. Bought it not running, supposedly a fuel issue but they didnt really know. So, I put in a good battery and started messing with it. It turns over great, but just wont start.
Fuel pressure 58psi at key on, changed pump anyway, no change
New fuel filter, same
Changed fuel rails and injectors, same
Changed FPR, same
Checked spark on all cyls good
Checked compression, all good
Checked fuel injectors firing, they all are.
Changed the throttle body, same
Changed cts, same
Changed MAF, same
Checked fuses, good
Did security relearn, same
Luckily I have all these parts on hand so it doesnt cost anything to play process of elimination, but Ive run out of things to try.
Thoroughly frustrated, have spark, fuel, and compression, shouldnt need much else. Im going to try the security relearn again, but Im not optimistic. What am I missing?? I read crank sensor will stop spark, so it cant be that. Cam sensor should start 50% of the time.
Old Jul 15, 2013 | 06:15 PM
MOTTRHED's Avatar
Nothing huh? Tempted to start parting it out lol.
Old Jul 15, 2013 | 06:32 PM
MustangPunk's Avatar
Does it even run for a second, then die??... If not I doubt it's VATS then.. Cant hurt to do it again though I guess.
Old Jul 15, 2013 | 06:39 PM
Atomic's Avatar
I have a gauge for that
Pull the fuel pump fuse and have someone spray some carb cleaner or starting fluid at the throttle body when you try to start it. If it fires up you know its a fuel issue.
Old Jul 15, 2013 | 08:14 PM
axekick's Avatar
You need to scan it and see if it's reading any rpms while you crank. If a crank sensor doesn't send a an rpm signal then it will not open the injectors.
Old Jul 15, 2013 | 10:02 PM
MOTTRHED's Avatar
Every once in a while it will kick, but only a millisecond.
It will kick slightly better on starting fluid, but not enough to run even for a few seconds.
Injectors are firing, all of them, checked.
Old Jul 15, 2013 | 10:15 PM
thunder550's Avatar
High on diesel fumes
Long shot, but is it possible that the cam is not timed correctly? Maybe they tried a cam swap or timing chain replacement and didn't get everything lined up correctly?
Old Jul 16, 2013 | 04:48 AM
Suburbazine's Avatar
Change the crank sensor if you have parts to throw at it. Just because it makes a spark doesn't mean it's making it at just the right time. It's also possible that it could be flooding out OR the cats could be thoroughly plugged up.
Old Jul 16, 2013 | 07:32 AM
axekick's Avatar
I have seen flooding before on a swap. The plugs were wet and it wouldn't start at all. We swapped the plugs and it fired right up. Have you pulled one to see if there was fuel on it? That would also confirm that you're getting fuel through the injectors.
Old Jul 16, 2013 | 07:52 AM
whippled 8.1l build's Avatar
heres a silly one.. if your coolent temp sensor isnt working the engine wont start.. try and replace it or check the wires to it..
