No start, What am I missing?
Old Jul 16, 2013 | 08:05 AM
axekick's Avatar
Oh yeah, if that's not working it puts you in some pretty wild places in some of the maps in the tune. You really need to scan it and see what all your sensors are reading. It's so much easier to do it that way than swapping parts until it starts. Take advantage of the benefits of the efi system.
Old Jul 18, 2013 | 04:34 PM
MOTTRHED's Avatar
MASS seller approved
Pulled plugs when doing the comp test, didnt look flooded.
Had already changed coolant temp sensor, no change.
Injectors are firing, no question there.
I can try another crank sensor, I was just trying to avoid it as its a pain.
As for the cam vs crank timing, I would imagine it would have shown some sort of sign while doing the compression test, as it shouldnt really be right if your timing is off.
Old Jan 24, 2014 | 02:06 PM
MOTTRHED's Avatar
Well I had pushed this truck aside for the last 6mo or so, but Im starting to mess with it again. Tried today:
Checked spark again-good
Bypassed the whole fuel system by running a pump directly to the rail-no change
So tomorrow Ill do the crank sensor, and maybe even the cam sensor. Any other ideas I can try while Im at the garage tomorrow??
Old Jan 24, 2014 | 03:40 PM
TXsilverado's Avatar
unbolt the y pipe from the manifold and see if it will fire off to eliminate the exhaust being plugged.
Old Jan 24, 2014 | 04:08 PM
axekick's Avatar
That's a great idea!
Old Jan 24, 2014 | 04:27 PM
MOTTRHED's Avatar
Lol, this is NH, you dont just unbolt a y pipe. The studs will snap, then you have to pull the manifolds, and those bolts will snap, then you have to pull the heads.... you guys are so lucky without rust.
Old Jan 24, 2014 | 04:30 PM
atleast put your hand over the exhaust outlet and see if it feels like it is flowing freely. if not, hack out the converters and weld a piece of pipe in.
Old Jan 26, 2014 | 04:14 PM
MOTTRHED's Avatar
Yes exhaust is flowing fine.
This is interesting though, seems Ive developed a new symptom.
Turn the key on, the fuel pump turns on for one second literally, like no where near long enough to prime the system to pressure. Then it shuts off, and doesnt even turn on when cranking. Im starting to think I have a pcm issue.
So, I ran a second pump from a 5gal bucket directly to the rail, powered it up, still doesnt start.
Old Jan 26, 2014 | 06:20 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Is the Security light flashing? If so it could be killing the pump.
I have a feeling you have an issue with the BCM or the electronic switch in the key cylinder.
We had this same issue on a truck and had to have both changed and reflashed at the dealer.
Old Jan 26, 2014 | 08:48 PM
MOTTRHED's Avatar
No flashing security light. I think you are probably right, its got to be something like that. Got to decide what to do, truck isnt worth putting a ton of money into.
