no gauge lights in cluster
Old Jan 12, 2014 | 09:12 PM
brizzle815's Avatar
Default no gauge lights in cluster
2000 silverdo in sig
I have no gauge cluster lights.
All gauges work fine other than lighting up at night.
Radio lights up and works fine
Ac control lights light up fine
dome light works
dimmer switch works
The digital read out in the middle works. Will also dim and brighten when dimmer switch position is moved along with ac and dimmer switch lights.
I check all fuses that would control gauges. good
I also check all fuses suggested through google searches. good
I also literally check every fuse in fuse panel under hood and inside cab on driver side. Good
From what i read online i believe i may have i loose wire in behind the dimmer switch. just assuming. I havn't got that far yet. Just wanted to see if you guys or girls have any suggestion into pointing me in the right direction.
I should also add. they were working at one time. i believe i was missing with the dimmer switch one day during the day and drove truck at night days later and noticed it.
thanks for any tips
Old Jan 12, 2014 | 09:40 PM
Suburbazine's Avatar
All the light bulbs finally burnt out. If the gear selector dims properly then the wire to the cluster is hooked up correctly. Just have to pull the cluster out and put 7 new type-194 bulbs in.
Old Jan 13, 2014 | 05:38 PM
brizzle815's Avatar
I wouldn't think all the bulbs go out at one time.
Next chance I get I'm going to pull cluster.
I will try change bulbs and see if that works.
Old Jan 14, 2014 | 02:33 AM
If they didn't go out, you have a defective cluster. It's not unusual for these clusters to have solder joint issues, particularly around the connector base. Soldering on them is retardedly difficult, due to the tinfoil circuit traces and crappy through-board traces.
Old Jan 29, 2014 | 09:03 AM
Silverado777's Avatar
Replace your dimmer switch. It is most likely the cause. If they went out one by one I would say it's the bulbs on the gauges. But since they all go out at once it points to the dimmer switch.
You could always call this guy and talk to him
GM Gauge Cluster Repair and L.E.D Conversion with LIFETIME Warranty
Old Jan 29, 2014 | 09:11 AM
It's a 2000. They are twist in. They do not solder in.
Idryfly5
Sep 2, 2022 08:55 PM
kalikid06
20
Oct 13, 2015 07:37 AM
06 4.8
Sep 11, 2015 10:36 AM
silver-mod-o
Sep 7, 2015 10:22 PM
the owl
Sep 4, 2015 04:09 PM
