new engine starter wont work
#22
i didnt check that one. ill check it tomorrow when i get home from work. and i need to get a wire thin enough to try and jump those pins. i thought it would be those because the relay shows those as a switch but i wanted to make sure.
#27
I believe there usually somewhere around center or slightly off to one side.
#30
ok so i adjusted the neutral sensor and hit the key got a click from the starter and now my dash is dead and i have no power to the starter again. i checked the crank and main fuse and they are fine. i have power to the dome light and the annoying beeping when the key is in comes on. im thinking i may need a new wiring harness. any suggestions? i obviously have a ground somewhere.
